Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 04-10-2016, 05:39 PM   #1
sadpontiacdriver
Can't read Tranny fluid level...
After running the car for half an hour to bring it to "normal operating temperature" I still can't read anything on the ATF dipstick. It comes out clean, no fluid on it at all... EVEN after adding half a quart of fluid.
HELP! I don't want to overfill and kill my transmission!
Oops! EDIT: 1992 Honda Civic 4-door, 1.5L
sadpontiacdriver is offline   Reply With Quote
Old 04-11-2016, 09:45 PM   #2
sadpontiacdriver
Re: Can't read Tranny fluid level...
/bump
I need help, guys.
Old 04-11-2016, 11:52 PM   #3
harleyguy
Did you do tranny work or has it been leaking? If no to both it's odd that it's low but I would say slowly add till you see it
harleyguy is offline   Reply With Quote
Old 04-12-2016, 12:48 PM   #4
somick
somick's Avatar
I am not sure about Civic but on my Accord you read the ATF level with the engine off.
Originally Posted by RIP
Please post back when you fix it so we all will learn something
somick is offline   Reply With Quote
Old 04-12-2016, 08:04 PM   #5
sadpontiacdriver
No transmission work has been done to that car AFAIK.
I checked the ATF level because it felt like the shifting was a bit jerky. After adding fluid, it felt a bit smoother... But the dipstick is not showing any change. If I look down into the ATF dipstick hole I can actually see the fluid about half an inch from the opening.
I checked the ATF after bringing the car to operating temperature AND turning it off. The manual doesn't specify if the car needs to be on or off, I assumed off.
Thank for the replies.
Tags
atf , dipstick , fluid , transmission
