Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix
Old 02-19-2016, 12:27 PM
glc4123 glc4123 is offline
1997 pontiac grand prix 3.8 transmission trouble
yes, i own a 1997 pontiac gp se 4 door with automatic transmission. when the car isn't runned for a day and when i start off it slips for a little until it shifts to the other gear, then it doesn't slip till the next day after sitting overnight? it has 243,000 miles never had trouble till now. i changed the filter and trans fluid approx. 4 years ago. any help will be appreciated.
thanks
Old 02-19-2016, 09:22 PM
Tech II Tech II is offline
Re: 1997 pontiac grand prix 3.8 transmission trouble
Tranny with that amount of mileage and years, could have seal problems......AS THE FLUID HEATS UP, makes those hard seals a little more pliable, and they seal better....
Old 02-20-2016, 03:42 AM
yes, thanks for the help, would lucas transmission addative help or hurt transmission?
Old 02-20-2016, 09:14 AM
It's my belief, that "fixes in a bottle" have their limitations.....
They should be used more for preventive maintenance, rather than a cure.....
That being said, is the car worth having a major transmission overhaul? No.....
How much longer do you plan on keeping the vehicle?
To do nothing, it will probably get worse.....
Will it hurt? I have no idea.....you have to make that decision....
Old 02-20-2016, 02:33 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Lucas isn't a cure-all. Its one of those things you add as soon as a problem presents itself and hope for the best, or as stated, its used as preventative maintenance.
The other problem with Lucas is if you add some you're going to have to remove the same amount of trans fluid you intend on adding or you will overfill the trans and there is no easy way to remove fluid..
Speaking of that have you checked the fluid level? If its low it could cause your problem. Basically once the pressure builds up from the pump running it could then let the problem go away.
