Ticking noise in the passenger side dash
I went to start my 2001 bravada this morning to find there was no power and a fast clicking noise coming from the passenger side under the dash. It would stop whenever I would turn the key over. im not very savvy with cars so I'm hoping someone can help me figure out the problem
Re: Ticking noise in the passenger side dash
Sounds like an electric powered door on the heat and AC system.
Does your Bravada have Climate Control, can you set the temperature to a specific number? |
Sounds like you have short circuit. The clicking noise will be very helpful since you just need to pull fuses and put them back in until you isolate the problem by the noise stopping. If it is a climate control problem like Chris thinks it is then you may be able to get it running again by pulling that fuse and fixing the problem later.
I has similar problem. Is it coming from under the glovebox? Like 4-5 clicks? It's the TCCM. If you open hood and pull ATC fuse should rectify. I also pulled the 4x4 fuse in the door to be certine. Is your service awd light on as well?
Sav |
