Oil loss/ Tuneup
I have a 00 Siverado 1500 Z71, 4.8 Vortec, Automatic with 274,388 miles.
I had the oil changed at 272,000 and have had yo add oil twice since. I have had the Valve cover gaskets, Oil pan gasket and Rear main seal replaced recently. I cannot find any sign of leak under truck. Truck is not smoking at all. But every 1200 miles or so my check engine oil level light comes on. Also I will be doing a Tune up soon and was wondering if any one as suggestions as to What are the best Spark plugs and Plug wires to use. |
Re: Oil loss/ Tuneup
what oil do you use meaning viscosity and type meaning conventional or synthetic. most times this can be simply the PCV needs replacing also check that the hoses of this crankcase venting are not damaged in any way. I would also check that the fuel regulator vacuum line does NOT have fuel /vapors in it .. the spark plugs I use are iridium ac delco. these plugs will last some say 200K miles. my plugs are at about 50K miles still look new.. reason is the metal can take the very high heat in these engines... older engines cast iron heads plats are good but NOT in these .. tips burn off.. plug wires maybe good.. if you used dielectric grease in the boot ends and they are not cracked. measure resistance should be around 600 OHMS .. being short and not near heat these last forever.. on the old 350cu .. plug wires need replacing heat damage. I always measure and inspect the OHMS and wire condition .. use the proper tool to remove wires from plugs. that is how these do get broke ! |
Thanks for the info Jcat. I use 5W30 Amsoil full synthetic oil. Seems like I am having to put in 1 quart every 1200 miles.
I would replace the PCV and make sure those hoses are working properly .. how much blowby do you have ? remove the oil fill with engine running does it create lots of oil vapors ? what engine oil pressure do you have ? just wondering how long you owned this , and how long this , has been using synthetic oil. what filters you use ? my 2000 5.3L truck has almost 170K uses 1/3qt in 7500miles which is when I do my oil change with mobil 1 and pure one Purloator or wix oil filters.. original owner....... |
I have had the truck for 10 years. It had 86,000 on it when I bought it. I've run only Amsoil 5w30 per Manufacturer spec. I use an Amsoil filter and change the oil every 5,000 miles. Oil pressure has always been 50-60. I got the truck through an auction and have no service info or any idea what it was used for. It came with a factory tow package but that's all I really know. The mechanic who does all my work for me suggested going to a Higher viscosity oil. He said he had a similar issue with his Expedition and it helped quite a bit. Having the oil changed in a couple days.
I wanted to add that many folks, even automotive experts, consider oil consumption which is equal to or less than 1 quart per thousand miles to be perfectly acceptable.
My '02 Silvy 6.0 has 242,000 and uses very little oil in city driving. But on high-speed highway drives, it uses about a quart every thousand miles. I have never seen oil smoke from it, but I think even at a quart per thou, it is not going to be burning enough oil to make any visible smoke. My guess is the rings are going, so at higher RPM it is slinging a lot more oil up onto the cylinder walls, and the rings are no longer able to cope with it like they could when new. I use also use full Synthetic 5/30 oil.
-Jim 2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4 2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck 1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...). ![]() 1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint! 1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now). |
