2001 Suburban high idle delayed shifting
My 2001 Suburban, 1500, 5.3L, 2WD with 164k miles, has a problem with high idle and delayed shifting. The high idle occurs when the vehicle has been driven around for awhile. When I start it up, even when already warm, idle is normal (~600 rpm). After some time, however, it idles at 900 to 1100 rpm. The delayed shifting happens right away--almost like I have the tow/haul mode turned on.
I have cleaned out the idle air port, cleaned the MAF sensor, replaced the idle air control valve, replaced the PCV valve, replaced the engine temperature sensor, and unhooked the battery to reset things. It still idles high. I first noticed this a few weeks ago when the battery died. After I put in the new battery, the idle was very low. So I cleaned out the idle air port and valve. Then it was high. I drove it around for a few days like that and then started replacing stuff, to no avail--still high. Any suggestions? P.S. I also cleaned around the throttle plate. Last edited by drchemistry; 06-10-2015 at 09:36 PM. Reason: add more info |
Re: 2001 Suburban high idle delayed shifting
I rushed out to buy parts before reading the manual. The factory manual says to idle the warmed engine in drive for 5 minutes, then in park for 5 minutes to reset idle after disconnecting power. That seems to have worked, so I just wasted upwards of $200 in unneeded parts.
After a week the truck is still idling and shifting fine. The reset seems to have worked.
if you tried to move the IAC valve then this is why it changed when you cleaned it. |
