Go Back   Automotive Forums .com Car Chat > Chevrolet > Equinox
Old 04-23-2015, 10:19 PM   #1
rlanders
2008 equinox Brake problems.
I have a 2008 equinox and I am having problems with brakes it feels like they are being applied while driving down the road and then get tighter and tighter until the car just won't move while at the same time the brake pedal gets firmer and firmer. I am getting a code c0131 on the datalink. I pulled the fuse to the abs system but the problem still persist.
rlanders is offline   Reply With Quote
Old 04-24-2015, 02:00 AM   #2
Ruley73
Ruley73's Avatar
Re: 2008 equinox Brake problems.
You should take a look at this thread. The part that you'll find most helpful is the last post on the first page. In their case it was a bad master cylinder which was leaking into the brake booster which also had to be replaced as a result.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Ruley73 is offline   Reply With Quote
The Following User Says Thank You to Ruley73 For This Useful Post:
rlanders (04-24-2015)
Old 04-24-2015, 12:34 PM   #3
rlanders
Thanks for the info!! I replaced the master because it was leaking inside the booster. I found this quite by accident! I cleaned the booster out as best I could, I didn't think it would be causing the problem but maybe it is!!
Old 04-25-2015, 10:24 AM   #4
DeltaP
Do you still have the problem? But you DO still have a problem. I wouldn't trust cleaning out the booster. Once the booster diaphragm is contaminated with brake fluid its only a matter of time until it fails. In regards to the orig problem I've read: The brake pedal position sensor relearn procedure will need to be done as well as the steering angle centering relearn. A TECH2 scan tool is needed to perform the recalibrations. HTH
DeltaP is offline   Reply With Quote
The Following User Says Thank You to DeltaP For This Useful Post:
rlanders (04-26-2015)
Old 04-26-2015, 10:23 AM   #5
rlanders
Yes I am still having the problem. I am going to replace the booster today. Thanks for the info. I will check on the sensors after I finish replacing the booster.
Old 04-27-2015, 11:22 PM   #6
Ruley73
Ruley73's Avatar
The service manual doesn't mention anything about recalibrating or relearning any sensors. I can't see why it would be necessary either. You're not messing with the steering system at all and the brake pedal position should remain unchanged. I've attached the instructions for replacing the power brake booster below.
2007-2009_Equinox_power-vacuum-brake-booster-replacement.pdf
My rides:
- Steve Smith (Red)
Old 04-29-2015, 01:30 PM   #7
rlanders
Thanks for the info! I got the new booster on last night, my plans are to get everything else hooked back up and bled tonight. Hopefully everything will go well.
thanks again for the info!!
Old 05-02-2015, 09:57 PM   #8
rlanders
I finally got everything back together and what little I've been able to drive it I think this has solved my problem. If I have any more trouble with it I'll be back. Thanks again for all the info, It really helped a lot.
Old 05-04-2015, 03:46 PM   #9
rlanders
Still having the problem!! Any other ideas?
Old 05-04-2015, 09:15 PM   #10
Ruley73
Ruley73's Avatar
I'd check for sticking calipers. More specifically, make sure the guide pins on all the calipers are properly lubed with brake caliper grease and moving freely. If that checks out, inspect the front brake hoses. If the bracket attached to each hose that bolts to the strut is really rusty I'd suggest replacing them. A rusty bracket could be restricting the flow of brake fluid through the hose which may cause your caliper(s) to not release. The logic here is that your brake booster & master cylinder force fluid through the crimped hose when you push on the brake pedal, but when you release the pedal there's nothing to force the fluid back through in the opposite direction. The bad hose basically acts like check-valve.
My rides:
- Steve Smith (Red)
