Go Back   Automotive Forums Car Chat > Toyota > RAV4
Old 01-29-2015, 06:53 PM
turkey28 turkey28 is offline
2003 Rav4 fuel pump
I believe my fuel pump is bad. I can't figure out how to get the access panel out of the floor. All the instructions I have seen say to remove the 4 bolts but there aren't any bolts. Do I just pry it off, twist it, or???? I don't want to break anything.
Old 01-30-2015, 03:24 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 2003 Rav4 fuel pump
not sure if this is the same as a 2003 or not
https://www.youtube.com/watch?v=Z_F-6Zt0AlY
Old 01-30-2015, 03:25 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Make sure you're looking at the correct panel. There may be more than one type of access panel back there.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-30-2015, 05:03 AM
Thanks for the reply. I watched that video before, it's not the same. Mine has a round cover with no screws. when I pulled out the wire grommet I could see the pump was under there. It looks like there is black sealant around the cover. I think I'll pry on it a little and see what happens.
Old 02-08-2015, 01:49 PM
I finally had time to replace the fuel pump. Running a putty knife around the access panel popped it off.
It will start and run if I keep the RPMs up around 2000. If I let it idle it will die and be very hard to restart, if it will start at all. Sometimes even while holding it at 2000 RPMs it will start stumbling and die.
I'm thinking maybe I should have replaced the pressure regulator along with the pump.
Any ideas?
Old 02-13-2015, 01:18 PM
maxwedge maxwedge is offline
A990 racer
How about checking the pressures while the problem occurs?
