| Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
1999 s10 truck problems
few months ago, my truck started to stall. It happens if I go real slow, if I'm in a drive thru, or at a stop light/stop sign. It's like it wants to die and the only way I can "kick" it out of that is if I basically floor it and gain good momentum back up. It also smells of gas and sputters. It sounds like a lawnmower when I start it lol and shakes. Any ideas? Thanks!
SHO No Mo
![]() Join Date: Jun 2004
Re: 1999 s10 truck problems
It sounds like you have a misfire, likely either due to an ignition issue or a vacuum issue. When is the last time the truck has had a tune consisting of at least spark plugs, plug wires, and fuel filter? I think your 1999 is distributorless ignition, but if not, you should add distributor cap and rotor to the list as well.
You also need to check under the hood for and damaged or disconnected vacuum lines and also inspect the tubing between the air filter and the throttle body to make sure there are no cracks in that. Pay particular attention to the connection points as well as between the accordion folds. -Rod |
