Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 08-10-2014, 08:35 PM   #1
pottss55
2007 silverado 1500 rattling cat
thought i had the dreaded cold start piston slap but discovered it was left side cat rattling internally on cold starts only makes noise for about 30 seconds. head pipe has been down 3 times due to transmission issues.. my question is if i gut the cats out will it damage anything or throw out codes ?I understand legal the ramifications ,just didn't want it to break up and plug up.
pottss55 is offline   Reply With Quote
Old 08-10-2014, 08:57 PM   #2
gmtech1
gmtech1's Avatar
Re: 2007 silverado 1500 rattling cat
Yes. It will set a cat efficiency code and/or 02 sensor codes. You will also fail emissions testing if you have them in your area.
gmtech1 is offline   Reply With Quote
Old 08-11-2014, 11:13 AM   #3
j cAT
most times that rattle is the outer skin. get some steel wire and wrap around the skin see if it is reduced or gone.. if it works buy some stainless steel wire to make sure it will last...
Old 08-13-2014, 08:43 PM   #4
pottss55
thanks for responses , there isn't any heat shields on cats just the solid can of the cat. Have been under truck when starting and can hear rattling inside of cat , hate noise but not ready to dump 300 on new headpipe
