| WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum. |
53 Chevy Bonneville Bruiser
Heres one my son Ian, 13 at the time, conceived of. I drew up a sketch and
went out and bought 3 models and started hacking away. The 3 kits are AMTs Wagon Rod, The 1950 Chevy (street version) glue kit and a Snap Tight version of the same kit as a back up. With the exception of the exhaust dumps, this is what we're after... ![]() Here's where I'm at so far; sorry about the picture quality - - - It's nearly ready for paint: ![]() ![]() |
Re: 53 Chevy Bonneville Bruiser
more:
Cool build! It looks like you have put a lot of thought into it. Is that a Revell 37 Ford chassis?
Mark |
#4 | ||
Wow man!!! Is that all chopped and channend? I see there are off color lines, but it looks so perfect, can't even tell for sure! Excellent! |
Your sketch is cool. In the first photo you can see how close you have managed to get to that sketch. You've obviously put a lot of time and effort in to it. I look forwaerd to seeing it finished. Do you aim to paint the red pinstriping?
#6 | ||
And I was giving him tips for build materials... No wonder he hasn't gotten back to me , that boy knows his stuff. Now, in long hand, here's the breakdown on the mods: My goal was to have to use as little body filler as possible so I used the glue and styrene along with tight tolerances as much as possible to accomplish the following: 1.) I chopped roof (appx. 3 scale inches.) and was able to spread the A and C pillars in which used off-set cuts on each for strength. The rear window was cut out and kept the stock size and "welded" back in with cuts made to the roof for fit. I added 1/16" evergreen sheet styrene cut to the shape of the roof to fill the for/aft gap in the roof and doors; sanding the roof to shape and carefully carved the door reliefs and drip moldin with #11 blade and hobby files. 2.) After finding the straightest, most even area on the doors, I sectioned out appx. 4 scale inches from he body. It is relative to the height of the relief lines on the lower fenders. I cut the same amount of material out of the cowl at an angle using the straightest part of the hood as my guide. This was to insure proper fit as well as give me a guide for how much material I'd be sectioning out of the hood. 3.) The hood was sectioned/pie cut and sheet styrene added as needed to line things back up. You can just see the material I added between the top section and bottom used to reform and smooth the sides out. 4.) The fenders, front and rear, were simply cut and shaped, sheet styrene is used to replicate the reliefs. 5.) I used the front roll pan that comes in the street version of the glue kit but I filed and reshaped it for a smoother fit and finish. I used the lowermost grille bar to, in part, fill the gap left by the narrowed grille. Each bar was separated to narrow the spacing between each. It helps make the truck look even lower, I think. 6.) The bed is pretty much stock dimensions with the 'wells' cut out for tire clearance and brake cooling (Ha Ha!). Ian wanted the rear frame and suspension exposed as is common on severely lowered mini trucks so I used styrene sheet to mimic steel for the bed decks. The angled square tubes are stabilizers as there would be some serious rockin' and rollin' trying to rip the side rails free, otherwise. When racing, the gate would be lowered for better streamlining so I made it functional. I made roll pans for the rear and on the sides, in back, to hide the frame and gas tank. 7.) The frame was lengthened under the cab and mounting points adjusted to fit the cab. (Three times. Grrrr!) I altered the front cross bar, bringing it forward for proper wheel alignment with the wheel openings. The same is true of the engine and it's mounting points which I fabricated anew along with a longer drive shaft using styrene tube. I also moved the radiator unit forward. 8.) The interior was channeled over the frame and I fabricated a smooth firewall and transmission tunnel. With the exception of sheet styrene to fill the gaps, the rest of the interior tub remains stock. 9.) The moon discs were cut from the bottom center of aluminum soda cans and will be spun eventually. They cover a set of crappy old centerline rims that came with an old MPC Toyota Supra kit. The slicks are from The Lindberg Dodge 330 "Color Me Gone" kit I converted into a 4 door. (Police car with pictures to come.) The front tires are from AMT's Snap Fast Plus 'Cuda. 10.) The engine follows Ian's direction and will have a nicely detailed GMC blower with dual quads topped by short, throaty stacks I'll cut from 3/16" aluminum tubing. 1/8th inch tubes are bent into a set of lake pipes which dump off from the street legal exhaust system which Jairus so beautifully executed. 11.) The headlights are straight from the Wagon Rod and fit perfectly into the Chevy's stock openings tho I've frenched them a bit. (The easiest step of them all.) |
#7 | ||
This was the original photo as it had been photoshopped by another artist: ![]() Here's what I did to his picture: ![]() And then I went further to what you see at the top of the thread. |
#8 | ||
I found this on the other forum. Here is in Jairus own words, about the WgonRod kit:
#9 | |
That's cool. I didn't mean to be wrong about his involvement on the chassis design. It is well done tho. The interior, with all the 80's Corvette elements and the thouroughly
unthought out seats and door panels are the week spots for me. The cargo area is great tho. I started to build one I was given as a gift, which is why I chose it for the chassis. I made two alterations to the car by moving the headlights up about 1/4 inch and back a little bit. They're closer to where the stock pods would be. More stuff to take pictures of I guess. There's a single supercharger on a raised manifold. It's kinda cheesy right now but the boy wants it raise up out of the hood. I can't remember what kit that thing out of. It works well for getting things where they need to be for now. Thanks for the comments. |
#10 | |
This will be a very cool truck! I look forward to seeing more
"Artificial intelligence is no match for human stupidity." Current builds: 1950 Chevy Street Truck: http://www.automotiveforums.com/vbul...d.php?t=953839 Supra Drifter (FINISHED): http://www.automotiveforums.com/vbul...66#post6109966 1966 Volkswagen Beetle "Showroom Stock": http://www.automotiveforums.com/vbul...d.php?t=967968 1/12 Datsun 240Z: http://www.automotiveforums.com/vbul...90#post6415290 |
#11 |
#12 | |
Sweet, sweet tiny Hondas.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2003
This is stunning. Your clean fitting cutting and reworking is just... jaw dropping. I am very excited that you're sharing this!
It ain't cool 'till your wife hates it. Imagine a world without Alabama Recent builds: Rocket Bunny FR-S and stock BRZ Toyota bB Bro-style Civic K20 powered SiR converted EK WIP I build slowly and poorly.
#13 |
#14 | |
As our ways would go, it wouldn't seem right, to not paint it. However, I see your mods as something like a perfectly welded, seamed, hotrod in bare metal. Sometimes you just don't need the paint. But, bare styrene just isn't as flattering as bare steel. So good luck with the dam paint!
#15 | |
Excellent project. I love the old school aspects like the moon caps,(thanks for the great tip in making them). This will be a beautiful model when its done.
