Old 03-14-2014, 11:36 PM
Raccoonmama1 Raccoonmama1 is offline
stalling
My daughter's '914 K2500 pickup will run great most of the time but occasionally, it will quit while she is driving and she has to play with the gas pedal to keep it going. The first couple times it happened, we ran some carb cleaner through it and it got better.
This time it didn't help. Today she was driving and it was fine, then kept quitting. It stopped 17 times in a 12 mi. stretch.
Any ideas what it may be?
Old 03-15-2014, 11:54 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Re: stalling
Need more information on the engine, but assuming it's a 350....have you checked the plugs, wires, distributor cap/rotor, and checked for vacuum leaks?
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 03-15-2014, 12:55 PM
Re: stalling
It is a 350, no vac leaks, plugs are ok, haven't check the other things for a couple months
Old 03-15-2014, 01:44 PM
j cAT j cAT is offline
Re: stalling
what is the year and also the injection type ?
If the engine runs good then suddenly cuts out. no codes then you must check for bad fuel/pressures/fuel filter[cut open inspect] ...
I know that many run there vehicles with low fuel levels. if this is whats going on then the fuel system is a good guess !
[1/3 IS THE LOWEST IN THE FUEL TANK]
