99 MOnte Carlo elect. engine fan test
G'Day
I live in Arizona with temps in the 105 range during the summer. Since I just bought this car I want to make sure the electric engine cooling fans work. I haven't heard them come on in the little time I've driven it. Is there a way of testing them to make sure they work and at what temp. they start up? Thanks in advance. Murph |
I've had my 99 monte carlo for almost 2 years now and have never heard my fans come on either.. so last week I opened the hood and let the car idle in the driveway.. fans never came on.. temp gague went up to around HALF WAY.. I turn the Air conditioner on and the fans come right on cooling the motor back down and the temp gague went back to it's normal 1/4 way up from the bottom.. Maybe there's a fuse or relay of some kind that is blown on our cars?
Pimpin' ain't easy
No, what happens is the coolant is able to sufficiently cool the engine, without the help of a fan. There should be two fans, a cooling fan, and an A/C fan for the air conditioner. The reason both fans came on for you, is bacause the alternator draws voltage to run the A/C fan, making the engine idle higher, making more heat, adding a need for the cooling fan. I don't think your supposed to be able to hear it when driving.
Thanks for the reply- Do you know how high the temp gague is supposed to read if the car is just at idle parked? I've had the needle go a hair above half way.. i got worried so I turned the heater on full quick to cool it down.
G |
Pimpin' ain't easy
The thermostat is at 195 degrees, stock. I believe that is about halfway on the MC guages. It will run below 195 degrees until it is warmed up, then the needle should stay at or a bit past halfway.
