O2 Operating Range
What is the normal operating range reported on a scan tool of upstream O2 sensors for a '96 K2500 w/7.4, also for fuel trims?
Thanks!
2005 Saab 93 Aero 1996 GMC K2500 Sub w/conversion pkg 1964 Ford Falcon 'vert 1980 Bradley GT2 96v Electric 1978 GMC Royale Motorhome 1978 Glastron/Carlson CV23; 460/Berk JE jet |
Re: O2 Operating Range
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
Normally large swings from 900mv to 100 mv.....
Fuel trims usually less than 10%, plus or minus....zero % would be a perfect running vehicle, so it will vary slightly above and then slightly below zero.... OBD I, didn't use a %, they used 128 as a base line, and readings would vary slightly above and below the 128.... |
Thanks for the info. Was curious about it because I have one upstream O2 showing ~0.850 and the other showing ~0.08 at idle. I've been getting a bank lean code lately. I'm planning on replacing both upstream sensors.
could be vacuum leak. |
