Old 04-30-2013, 11:48 PM
lumina_98 lumina_98 is offline
Seems emergency brake is not releasing
When I release it then start in reverse often the car doesn't move then there is a loud sound from the right rear tire. If I don't engage the brake it reverse fine.I don't know where to start with this. I assume there is a cable going back to the wheel cylinders. Perhaps binding up somehow.
Old 05-01-2013, 10:10 AM
Tech II Tech II is offline
Re: Seems emergency brake is not releasing
Jack the rear of the car up.....apply ebrake......try to manually move the rear wheels......
Now release the ebrake...do one or both wheels move? If one moves and the other doesn't, then you have a problem on that side....
Discs or drums on the rear?
With someone applying and releasing the ebrake, can you see the cable to the bad wheel moving?
