06 Silverado Tranfer case
I have replaced my trans and now I have a problem with it going into fall safe mode. I was told it was to do with a sensor on the transfer case. Could this be my problem? I can turn the truck off and turn it back on and it will shift out, but when I stop and start to take off it goes back into the fall safe mode, staying in high gear.
#2 | ||
Re: 06 Silverado Tranfer case
what is the vehicle doing wrong ? never heard of fall safe mode before. what are the error codes ? drive train failure codes with a reader that reads these ? |
| The Following User Says Thank You to j cAT For This Useful Post: |
khwrbmlfe2013 (04-19-2013)
Thanks for the reply. I crank up shift into drive and it pulls off and shifts thru the gears when you stop and pull off it seems to be in high and will not shift. I then turn the truck off and start it back up and it then shifts thru the gears until I stop.
I have not had it put on a computer so I dont have any codes. Have been told it has to do with electronics at the transfer case. |
#4 | ||
anyway when these get eaten by the acidic fluid they can stick. sometimes you will loose 3rd or 4th gear when worn bad enough .. |
#5 | ||
khwrbmlfe2013, I see that jcAT is assisting you in regards to your transfer case situation. I would like you to know that we are also here to assist you. Thank you. Erica Tiffany Chevrolet Customer Service |
