Go Back   Automotive Forums .com Car Chat > Oldsmobile > Silhouette
Old 02-02-2013, 06:27 PM   #1
Ididnt[BreAK]it
Exclamation 2002 Sil Premre Sliding Door
Passenger side sliding won't stay closed, when its about to close it opens up .. is there a sensor that I need to check or does anyone have a break down picture that I can use to take apart so I can inspect/trouble shoot? Thanks
Ididnt[BreAK]it is offline   Reply With Quote
Old 02-02-2013, 07:29 PM   #2
gmtech1
gmtech1's Avatar
Re: 2002 Sil Premre Sliding Door
Try cleaning the contacts, both on the door and the pillar. A very fine emery cloth works well.
gmtech1 is offline   Reply With Quote
Old 02-02-2013, 09:04 PM   #3
Tech II
Also make sure there is no obstruction.......do you feel anything when closing the door manually with power door off? Also, do you know how to check for codes?
Old 02-08-2013, 11:14 PM   #4
Ididnt[BreAK]it
@ GMTECH1 - I did clean the contacts it worked 3 times .. sounds like it just fails before the latch lock the door .. @TECH II no obstructions and no codes .. manually closing does not want to lock/latch closed. its a hit and miss when it does close .. and when that happens I turn off the switch on the overhead. I sprayed lithium lube on everything .. lol Any other suggestions ? Thanks for the Replies
Old 02-09-2013, 02:21 PM   #5
Tech II
So if you turn the power to the PS door off, and manually try to close the door, it won't latch and close? Sounds like a latch problem....
Old 03-11-2013, 01:36 PM   #6
merc81
Just went through this myself. The door jamb in the back is out of position requiring too much force to latch shut. Loosen the two screws on the rear side door jamb and CAREFULLY nudge it outward a touch. The intent is to lesson the closing force needed to click that latch at the back.
I think its caused by age--maybe some rust under the door frame and things settle a bit.
Loosening the closing force just a bit will fix it.
merc81 is offline   Reply With Quote
Tags
2002 , door , olds , power , sliding
