Go Back   Automotive Forums .com Car Chat > Cadillac > Seville
Old 01-17-2013, 03:48 PM   #1
ellis479
Cool 1996 Eldorado Windshield Washer Tank
Hello,
What is the procedure to remove the windshield washer tank on my 1996 Eldorado ETC. It is leaking. I removed the filter assembly, but under it there is a large black plastic box with a metal part inside it. How do I remove this so I can get to the windshield washer tank for removal and repair? Thanks...... Ellis
ellis479 is offline   Reply With Quote
Old 02-12-2013, 11:07 AM   #2
ryanusrey2012
Re: 1996 Eldorado Windshield Washer Tank
Originally Posted by ellis479 View Post
Hello,
That large black plastic box with a metal part inside is your PCM (computer) You will need to look in a service manual to see the proper procedure to removing the PCM with no damage and your tank is not really exactly under that I believe there is a metal plate under your PCM and the tank is under that. As far as getting that box open there are two metal latches holding it closed one facing the headlamp assembly and the other which is nearly impossible to get your hand on facing the fender. When removed you can remove the bolts that hold the metal plate and access your tank
ryanusrey2012 is offline   Reply With Quote
The Following User Says Thank You to ryanusrey2012 For This Useful Post:
ellis479 (02-22-2013)
