Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 01-22-2008, 03:52 PM   #1
userunknown
short vs long shifter
opcorn: i have a short shifter and cant seem to get it to go in reverse. i was told that if i switch to a standered shifter that it will solve the problem any feed back people it is parked on a hill front toward a wall so i cant move it
userunknown is offline   Reply With Quote
Old 01-25-2008, 11:05 AM   #2
Doug Tatham
Re: short vs long shifter
Usually it's a problem with the linkage adjustment. You can get it close by feel, but you need the adjustment tool to get it right. Take it to a dealer. The longer shifter may provide the necessary leverage to break your linkage, but I doubt it will fix your problem.
I forgot to mention - get a rebuilding kit for the linkage. There are several bushings and stuff that wear out. This makes the shifting a LOT smoother.
Doug Tatham is offline   Reply With Quote
Old 05-15-2012, 08:46 PM   #3
BrantDavis
volkswagen, yes? does it have the reverse lockout? push down on the shifter as you put it in reverse
BrantDavis is offline   Reply With Quote
