Old 06-26-2012, 10:35 AM   #1
walleye17
2002 suburban rear axle seal
trying to replace axel seal have removed rotor and have rear cover off i see a pin held in with a bolt will i get in trouble if i remove it also see a clip that looks like it holds axle in place
walleye17 is offline   Reply With Quote
Old 06-26-2012, 10:51 AM   #2
maxwedge
A990 racer
Re: 2002 suburban rear axle seal
Removing the small bolt, be careful they break easily, then you can remove the cross shaft pin, push the axle in and remove the c clip, try not to lose the position of the spider gears or it can be a pita to get it all back together.
Old 06-26-2012, 08:39 PM   #3
j cAT
the bolt can break. If it does I used a reverse drill bit. only occured once for me.
when installing the bolt clean threads and use medium lock tight. torque to the proper amount.
03 suburban rear axle seals NINFan Suburban 0 08-31-2010 04:30 PM
97 rear axle seals rrruschman 4Runner/GX470 5 03-18-2009 04:16 PM
98 L. Rear Axle seal blown barretdm 4Runner/GX470 2 01-28-2005 09:52 PM
2000 S-10 rear axle seals Terri48 S-10 1 10-31-2004 10:36 AM
frontier rear axle seals frontier driver Frontier | Navara 0 05-24-2004 11:24 PM
