Old 07-05-2012, 02:53 PM
JLT89 JLT89 is offline
Help my turn signals and hazards won't work
I just bought a 2002 Civic. One of the first things I did was put my aftermarket stereo and taillights in. Then when I went to drive it, my blinkers wouldn't work. I've checked fuses and bought a new flasher relay and they still wont work. Is it possible I disconnected a wire by accident? If a bulb is blown would it keep all the signals/hazards from working? I'm certainly no expert, so any help is appreciated.
Old 07-05-2012, 03:49 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Help my turn signals and hazards won't work
You mention that you installed aftermarket taillights. Did you install LED taillights? If so, did you also install load resistors to maintain the OEM flash rate by properly loading the flasher circuit? Have you confirmed that the brake lights work?
-Rod
Old 07-05-2012, 04:00 PM
-Rod
Nope no LEDs or anything special, just new custom covers.
Old 07-05-2012, 10:14 PM
shorod's Avatar
SHO No Mo
Okay, next step would be to pull out the test light and check for power to the bulb sockets using a known good ground on the test light. If the test light lights, then either your ground to the sockets is bad or the bulbs are all faulty. If the test light doesn't light, then you get to start tracing backwards. Do you have access to a lighting wiring diagram for your car?
-Rod
Old 07-06-2012, 03:55 AM
urania urania is offline
If the hazards and turn signals did not work, maybe the problem is the button or the relay, a wire somewhere or the bulbs have burned out.
Old 07-06-2012, 06:16 AM
Jeff Collision Jeff Collision is offline
You may got in short in one of the wires or connections in the wrecked area. Inspect and replace any bad wires or connections.
Old 07-06-2012, 08:54 PM
shadows shadows is offline
disconect every wire you connected up- most likely you tied into the wrong wire
Old 07-07-2012, 08:04 PM
Well I've narrowed it down to the hazard switch. I'm gonna get a new one and I wI'll post results. Thanks for all the replies.
turn signal and hazard lites works intermittently on 97 taurus information7 Taurus | Taurus Wagon 4 10-01-2009 06:44 PM
97 Cutless Supreme - turn signals and hazards not working rbry Cutlass Series 1 12-08-2007 03:08 PM
92 camry turn signals and hazards don't work dirtbikemom Camry/Camry Hybrid/Vista 10 12-29-2006 08:28 AM
