Old 07-04-2012, 07:58 PM   #1
Joker5354
Question What is the material build up on my rotor?
First post, so i hope this is the right form.
Ok, so a brief history. My car is a 2007 Ford Fusion SEL AWD. Probably less than eight months ago i installed a new set of rotors and break pads on my car after finding my old pads and rotors were worn down. I bedded them in as per the manufacturers instructions and didn't seems to have any issues with them.
I should mention that I bought the complete set through a company on ebay. The reviews seemed good and the price for the complete set was less than what the local shops wanted to change me just for the front rotors alone.
Anyway, I recently had left my car undriven for a few weeks and those rotors rusted right over, my bad, but I do live in eastern Canada so everything rusts! Now, here I am a couple weeks later and I'm finding my car vibrates/pulses pretty bad when breaking (frequency of pulses slow as car slows). There is also a very slight vibration when driving as well. After some research, I've concluded that the issue is variation in rotor thickness due to material build up.
So, my question is what is this material build up on my rotor. As you can see in the pic there is a ring of rough material,which is on all four rotors, but i'm not sure if this baked on rust, material from the break pads or cementite due to overheating. I'm starting realize that I'm probably going to need new rotors "again", but maybe someone here has another idea.
Thanks for your help!
Joker5354 is offline   Reply With Quote
Old 07-05-2012, 09:13 AM   #2
vgames33
Re: What is the material build up on my rotor?
It looks like pitting from the rust. Turning is an option since they're fairly new.
vgames33 is offline   Reply With Quote
Old 07-05-2012, 09:52 AM   #3
curtis73
Professional Ninja Killer
curtis73's Avatar
It looks to me like cheap pads + foreign material = baked-on mess. Is it possible you got something on the rotors? A glob of grease from a ball joint? A squirt of tire dressing?
At any rate, turn them. You shouldn't have to remove much at all which will maintain the integrity of the rotor.
Dragging people kicking and screaming into the enlightenment.
curtis73 is offline   Reply With Quote
Old 07-05-2012, 04:46 PM   #4
shorod
SHO No Mo
shorod's Avatar
What about the anti-corrosion film that rotors typically ship with, might that be the baked on substance? At any rate, I'd agree that it's worth a shot at machining the rotors to see if you can true them up and reuse them.
-Rod
Old 07-06-2012, 11:41 AM   #5
Joker5354
Thanks everyone for the help. It's certainly possible that something else got on them, but since I'm having similar problems with all four rotors I'm leaning towards the surface rust that built up after not driving it for a bit. I'm going to try and get them turned to see if that works. Should hopefully save me some money!
Old 07-06-2012, 09:50 PM   #6
shadows
you can wash your car- spray water on the wheels and rotors- you can leave it sit- the rotors will rust
you can sand rotors to remove rust- you can drive it to remove rust- you can pay good money to have the rotors turned- they will still rust
in short- have a professional mechanic at a respected place check your brake system
shadows is offline   Reply With Quote
What is the material used to make body kit for car models????????????plzzzi wa onz civic Car Modeling 9 07-21-2010 01:09 PM
What engine is the logical build up? Trexz01 '88 - '91 Civic | CRX | Wagon | Shuttlee 17 03-29-2005 12:29 PM
New Member - heres what I am building at the moment mad4models Car Modeling 20 01-16-2003 04:10 PM
Whats the point of building when you can buy them like this? modelfan1 Car Modeling 5 02-01-2002 09:12 PM
