Go Back   Automotive Forums .com Car Chat > Fabrication & Tools > Machine Tools
Machine Tools Learn about metal lathes, milling machines and CNC tools.
Old 05-14-2010, 07:26 PM   #1
gbritnell
1/3 scale 302 Ford engine (running version)
Here's the stats on my model engine.
It's a 1/3 scale 302 Ford engine built entirely from scratch. The block is aluminum with the water jackets machined into it with iron sleeves for the cylinders. The heads are cast iron. The intake manifold is made out of 2 pieces of brass so that the runners and water crossovers could be milled. It was then silver soldered together and all the external runner detail machined. The exhaust manifolds are fabricated from stainless tubing and bar stock and TIG welded together. The crank is iron and the cam is steel. It has a full pressure oil system with complete cooling through the block, heads and intake manifold. The ignition is fully electronic with a Hall trigger in the distributor and a transistorized unit with a coil in the ignition box. It will idle down to 650 rpm and rev to just under 5000 rpm.
I have over 2500 hours (approx.) of build time on it. Here's a video link and a couple of pics.
gbritnell
http://www.youtube.com/watch?v=O_vQp0gevh0
gbritnell is offline   Reply With Quote
Old 05-14-2010, 11:17 PM   #2
Adam Baker
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Re: 1/3 scale 302 Ford engine (running version)
Wow man, just amazing. Ive thought about trying to do something like that eventually.
Adam Baker is offline   Reply With Quote
Old 05-15-2010, 12:35 PM   #3
534BC
How many cubic inches is it? bore and stroke size?
534BC is offline   Reply With Quote
Old 05-15-2010, 02:39 PM   #4
gbritnell
It has a 1.00 bore and .900 stroke. The full sized engine is 4.00 x 3.00 so in .3 scale it should be 1.200 x .90 but I reduced the bore size so I could get a little more water jacket around the cylinders.
gbritnell
Old 05-15-2010, 05:17 PM   #5
mike@af
Captain Over Engineer
mike@af's Avatar
Super impressive man! I've always wanted to build a running engine.
-Mike
mike@af is offline   Reply With Quote
Old 07-16-2010, 05:12 AM   #6
gionc
Authorized Vendor
gionc's Avatar
I'm stunned.........
gio
Old 07-16-2010, 05:24 AM   #7
gionc
Authorized Vendor
gionc's Avatar
PS: it sounds like a V8 at low turns.... umbeliveable... I really respect and admire your passion and the knowledge also.
gio
Old 08-13-2011, 12:12 PM   #8
kopperkart
kopperkart's Avatar
Incredible!
kopperkart is offline   Reply With Quote
Old 02-01-2012, 02:12 PM   #9
Tamm85
Have seen insane scrats building but that's really from different league !
Tamm85 is offline   Reply With Quote
