Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 03-19-2010, 07:01 AM   #1
LEM
'90 LX 5.0L 5-Sp Unintentional Revving
While driving into work this morning, my car started revving up to about 2,000 RPM when I stepped on the clutch. Every time I shifted gears, the engine wouldrev up to about 2,000. I seem to remember someone suggesting that the Idle Air Control valve might need to be cleaned. Any ideas?
Thanks.
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...
-2005 Yamaha V-Star 1100 Custom
-2008 Toyota 4Runner Ltd 4.7L AWD
-2019 Subaru Ascent (the wife's)
LEM is offline   Reply With Quote
Old 03-19-2010, 12:13 PM   #2
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: '90 LX 5.0L 5-Sp Unintentional Revving
Check for a vacuum leak first. Listen for a hissing noise along the vacuum lines. You can get a vacuum gauge also to check for proper vacuum pressure.
If no vacuum issues are found, than clean or replace the IAC valve. They've been known to go bad.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 03-23-2010, 02:45 PM   #3
HiFlow5 0
Stanger
HiFlow5 0's Avatar
Send a message via AIM to HiFlow5 0
These are all great steps to try. Also these cars also had a recall many years ago for the 10 pin harness needing a jumper wire installed by the dealer, to fix an issue similar to what you described. Do you have a dealer certified sticker stating that a 10 pin jumper wire assembly was installed? If you are driving when this happens, are you able to turn the car off and restart it without the issue happening again right away?
Technical Service Bulletin; 91E19 MAR 92 Recall - Wiring Harness Modification
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
HiFlow5 0 is offline   Reply With Quote
Old 04-11-2012, 10:54 AM   #4
LEM
Re: '90 LX 5.0L 5-Sp Unintentional Revving - Part Two
I’m resurrecting an older post. I'm having idle problems again. I replaced the IAC and it still is giving me problems. It's intermittent and I cannot see a pattern. This morning I drove it to work with no issues; drove home at about 9:30 AM and it started revving up again. I turned off the engine and restarted it and it seemed to calm down. On my way back to work at about 10:45 AM, it ran fine.
I have not heard any noise that might indicate a leaking vacuum hose. Where all do I need to listen for one? What else can I check?
Thanks.
