Go Back   Automotive Forums .com Car Chat > Lincoln > Town Car
Old 03-05-2012, 02:31 PM   #1
Recoil spring
Intermittent engagement of AC clutch?
The AC clutch on my 2000 Town Car has an intermittent engagement, when the AC is on you can see it clicking into position where it will hold ok for a few seconds, and then it disengages, and so on and so on. The AC puts out cool air and I checked the pressure connecting up to the low side port with a gauge yesterday. Plenty of freon in the system. Right now I am operating on "vent" to keep the car inside cool.
The sales man who sold me the Lincoln thought it was low on refrigeration, but I thought it was the clutch. Could it be a wiring issue, or a faulty switch? Ironically the small Ford wagon with a 4 cylinder engine I almost bought the previous day had the exact same problem, and both of them had around 102,000 miles. So it is something that all Ford products can have. Any ideas on what I should fix?
Thanks.
Recoil spring is offline   Reply With Quote
Old 03-05-2012, 03:20 PM   #2
olopezm
olopezm's Avatar
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Intermittent engagement of AC clutch?
There is no problem with the compressor, you might want to have it checked the refrigerant but other than that there is nothing to worry about.
That's the way these systems work with the automatic controls. Even if you're using the heater the compressor will kick in. That's why many users disconnect the compressor or one of the pressure sensors during the winter to keep it form engaging.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
olopezm is offline   Reply With Quote
The Following User Says Thank You to olopezm For This Useful Post:
Recoil spring (03-16-2012)
Old 03-05-2012, 09:57 PM   #3
Mx5guy
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
You either have a system leak, low on refrigerant, or have a blockage somewhere in the system the best way to find out is hooking it to manifold gauges.
Mx5guy is offline   Reply With Quote
Old 03-29-2012, 11:21 PM   #4
rprough
rprough's Avatar
Their probably is nothing wrong but in any case it might be the orifice tube.
God Bless America
rprough is offline   Reply With Quote
Old 03-30-2012, 12:51 AM   #5
aleekat
Many, many yrs ago that how the systems were designed. Then someone figured out not running the a/c for months in the winter was probably not a good idea. So then they decided to wire it when you put it in the defrost mode the compressor would cycle on. But it shouldn't cycle "every couple seconds"..
aleekat is offline   Reply With Quote
Old 04-18-2012, 08:24 PM   #6
Recoil spring
I have seen several other Ford AC's and even a Jeep one on You Tube doing this, engagement thing. The design of the clutch looks like it is intended for this function with the notches and the rubber bumpers on the clutch front plate. Older Lincolns have a different shaped AC assembly, perhaps it was a period design? With Summer coming I will run my AC and see what happens. Thanks for the replies.
1994 Blazer 4X4 intermittent engaging Zebisko Blazer 0 12-28-2005 06:38 PM
95 A/C won't engage clutch duffer37 C/K 4 07-12-2004 08:35 PM
