Go Back   Automotive Forums Car Chat > Buick > Regal
Old 03-12-2012, 08:44 PM
mn_1 mn_1 is offline
Lightbulb 99 Regal Unusual noise
This noise is difficult to describe. It almost sounds like something that drags for a second and then engages or hits a stop and the noise stops. More of a clunk type noise. When I start the car and back up 10-20 ft or so it will do it. Shifting to drive and moving about the same distance will do it as well.
Its definately in front sounds like drivers side. At night when it does this it affects the headlights (momentary flicker). Engine runs fine, shifts fine too. I dont see anything obvious underneath. Front hubs have been replaced, car has 52k miles. Steering is fine. Somebody mentioned ABS solenoid cycling, another said solenoids in tranny. Sorry I cant describe it better, a very odd sound.
Old 03-12-2012, 09:21 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 99 Regal Unusual noise
If it were the ABS solinoids, it would only do it when you first start the car, put it in gear and release the brakes and hit 3-5mph (somewhere around there). It would not repeat when you stopped and put the car in another gear and went the other direction. Only after key off then on again. Anyway you can post a video of the sound?
Old 03-13-2012, 12:06 AM
Smile Re: 99 Regal Unusual noise
How do I post a video of the sound?
Old 03-14-2012, 05:46 AM
patriot777 patriot777 is offline
In regards to your post about the abs solinoids happening during startup when the car first reaches 3-5 mph. My car does that......what can I do to fix it? It is usually a bad hub/speed sensor?
Old 03-14-2012, 08:04 AM
gmtech1's Avatar
That particular condition is normal, it is the ABS self test. If it particularly loud, you can check the insulators on the ABS unit and see if they are worn out. If they are you can replace them.
Old 03-14-2012, 10:20 AM
Scrapper Scrapper is offline
AF Premium User
have you tried to see if starter may be loose? just a thought?
Old 03-14-2012, 03:02 PM
It's fine. I'm thinking it may be the ABS self test.
1999 4.7 L Unusual Noise Left Valve Cover discnik Grand Cherokee | Grand Cherokee SRT8 1 09-09-2009 10:57 PM
1996 olds 88 unusual noise wagi62 Eighty Eight 3 09-18-2008 12:33 AM
Unusual Noise from Drivetrain Blue)(Fusion Crown Victoria 2 02-01-2008 06:24 PM
Unusual noise from rear of car JAA9579 Alero 4 02-17-2005 01:30 PM
89 Taurus - unusual noise oam Taurus | Taurus Wagon 6 11-25-2003 08:38 PM
