Go Back   Automotive Forums .com Car Chat > Ford > Ranger | Courier
Old 05-16-2012, 09:56 AM   #1
billkater
Send a message via MSN to billkater Send a message via Yahoo to billkater
1998 Ranger battery drain
In need of some suggestions.
I have a 1998 Ranger 4x4 auto with the 4.0 engine. No power windows or locks. After market remote lock/start system installed. I am have intermittent problems of a dead battery. I mainly use the truck to drive to work. About 2 miles each way.
Here is all the info I know so far:
1. battery installed 11/07
2. battery and alternator check out good at O'Reily's
3. At full charge battery has 12.6 volt
4. With engine running showing 14.5 Volt
5. With key off, doors closed, light under hood removed showing a .26 Amp draw
6. Remove fuse 27 (I think that the correct one), listed as GEM Speedometer. Amp draw drops to .08 Amp
Seems like a high Amp Draw to me, but I am unsure of what the remote lock/start system would draw. This has just started in the last 6 weeks or so. Dead battery once or twice a week.
I know the battery is at the end of it's life span. Does it sound like that is what it is or am I missing something?
Any clues?
Thanks
Bill
billkater is offline   Reply With Quote
Old 05-19-2012, 06:30 AM   #2
mrmikey
Re: 1998 Ranger battery drain
A fully charged battery with the surface charge (what happens immediately after a battery's charged) drained off should read 13.8V, your battery is toast......Mike
mrmikey is offline   Reply With Quote
1998 SL2 Won't start after Garmin use TrueCrew SC/SL/SW 0 03-19-2012 06:08 PM
2001 gls battery drain jetta_help_needed Jetta/Vento/Bora 7 02-18-2011 01:37 AM
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 05:18 PM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 11:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 07:30 PM
