Go Back   Automotive Forums Car Chat > Chevrolet > S-10
Old 02-03-2012, 08:35 AM
bwhntr4168 bwhntr4168 is offline
getting tough to start??
ok guys now, i bought this truck only a few weeks ago? it seems harder and harder to start??runs fine when started? its a 96 w/throttle body!
Old 02-03-2012, 10:39 AM
ricebike ricebike is offline
Re: getting tough to start??
start w/ the basics
battery load test,
cables to battery, ground wires...
Old 02-03-2012, 06:48 PM
j cAT j cAT is offline
what engine ? throttle body injection ? poor start means engine cranks good ? does not run .
this can be the engine coolant temp sensor on the intake manifold. also make sure the vacuum is good no leaks. especially the throttle body base area.
Old 02-04-2012, 06:09 AM
4.3 4x4 throttle body, cranks good but takes some time to start ? all new plugs wires cap and rotor!
Old 02-04-2012, 11:34 AM
since the battery cables are good & the battery is healthy, fuel filter?
Old 02-07-2012, 11:29 AM
EZFrank EZFrank is offline
did you check make sure your getting spark and fuel i had some issues with my 96 s10 and changed out bunch of stuff and still would not start i thought fuel pump which i did a few times thinking they where defective and found that i was getting no pressure at the pressure regulator and changed it out and solved my problems check your computer for codes i had P0300 cylinder misfire.
[IMG]http://[/IMG]
The Following User Says Thank You to EZFrank For This Useful Post:
bwhntr4168 (02-10-2012)
Honda gets tough on dealer pacts Automotive News Automotive News Desk 0 12-25-2006 12:10 AM
It's getting tough in the world of fast food '97ventureowner COMPLETELY off-topic 7 12-02-2005 08:20 AM
