Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 12-24-2011, 12:32 PM
cnk2002s10zr2 cnk2002s10zr2 is offline
02 s10 4.3 start problems
my 2002 s10 4.3 want start unless u push the gas pedal down a little bit.Then it will start but if u don't hold the pedal down for a min at 1 to 2 thousand rpms it will die what mit be the problem.
Old 12-24-2011, 01:20 PM
maxwedge maxwedge is offline
A990 racer
Re: 02 s10 4.3 start problems
Welcome to AF, a few things can cause this, faulty idle air control, or carboned up passages, coolant temp sensor skewed, a full scan should be done to look at sennsor inputs, I assume this is a cold start issue.
Old 12-24-2011, 02:14 PM
yes its a cold start problem.I used a scan tool and nothing poped up on the sacner the problem started after i had the intake manifold gasket replaced it run fine before.
Old 12-25-2011, 02:03 PM
A990 racer
No codes, but what do the int.and coolant temp sensors read when cold?
Old 12-29-2011, 04:11 PM
could it be a bad iac valve
Old 01-09-2012, 11:26 PM
it was the iac valve .I cleand it and unpluged the battery and it started right up and idles fine now
2000 s10 blazer 4.3 starting problems NHRA S-10 19 03-04-2011 09:11 AM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 10:11 AM
1991 s10 4.3 tranny problems? escort_jay102 S-10 0 12-05-2008 08:06 PM
92 s10 4.3 wont start broman333 S-10 3 04-18-2006 12:06 AM
need help 93 s10 blazer vortec 4.3 starting problems cfb Introductions 0 10-09-2005 01:15 PM
