Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 03-25-2012, 09:36 PM   #1
fiq
Cannot start my 94 xj...
here are my xj specs:
all in standard condition..
one day, i just changed my battery..suddenly my engine get hard to start...got missfire too...i just change my distributor rotor, pulg n wire plug...why dis happen?n now it just crank n cannot start...help me..im new here...thanx to all..
fiq is offline   Reply With Quote
Old 03-27-2012, 12:56 PM   #2
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Re: Cannot start my 94 xj...
First thing I would check is to make sure your battery cable connections to the battery are tight, since it started after the change.
After that, check the DIY section, there are several threads on no-start fixes.
Also, the following info will help us help you:
How many miles? Auto or manual trans? Any symptoms like this before?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
The Following User Says Thank You to fredjacksonsan For This Useful Post:
fiq (03-31-2012)
Old 03-27-2012, 11:21 PM   #3
MagicRat
Nothing scares me anymore
MagicRat's Avatar
These Jeeps are notorious for crankshaft position sensor failures, which would cause a no-start as you describe.
It's common enough that some serious Jeep owners carry a spare
MagicRat is offline   Reply With Quote
Old 03-31-2012, 09:22 AM   #4
fiq
250k miles...manual trans...its never been like dis before...its really start after i change the battery..n fyi, before i buy a new battery, i just did my stupid idea like jump straight from other car to start my engine...without the battery..is it can cause any damage to the engine part?
Old 03-31-2012, 09:52 AM   #5
fiq
is it anything bout my fuel pump?
Old 03-31-2012, 12:57 PM   #6
fredjacksonsan
Jump starting the vehicle should not have caused any issues.
Since you said this started immediately after changing the battery, have you made sure the battery cables are properly tightened?
MagicRat is correct, the CPS can cause a no start condition. But since this started suddenly (it DID start suddenly, right? Have you been having start problems before the new battery?) I'd think it had something to do with the work that was just done.
Old 04-01-2012, 01:37 AM   #7
fiq
MagicRat is correct, the CPS can cause a no start condition. But since this started suddenly (it DID start suddenly, right? Have you been having start problems before the new battery?) I'd think it had something to do with the work that was just done??.
yeah..the battery cable are tight enough...its never been like dis before..just after i change my battery...the last time i cant start just because of my old battery..n after got a new one battery, its become misserable..hard to start...got missfire...n just can idle in a few second then the engine shut off..n now its cannot start anymore..just crank till low battery..
i just check the CPS..maybe will take it off dis evening..its a big problem to get the jeep part in malaysia...
Old 04-01-2012, 10:39 AM   #8
fredjacksonsan
OK understand the part -the CPS - is difficult to buy in Malaysia, but that could be the problem.
You can try disconnecting the battery cables, then holding them together for 15 seconds, sometimes that sort of reset can help.
Old 04-01-2012, 09:31 PM   #9
fiq
thanx again..will try dis evening
Old 04-02-2012, 12:36 AM   #10
fiq
how to i makesure dat dis problem is nothing bout my fuel pump?how to check my fuel pump cndition?
Old 04-03-2012, 09:57 AM   #11
fredjacksonsan
Several threads here about testing fuel pressure. Sorry, but I have never done it.
Old 04-03-2012, 11:05 AM   #12
fiq
where u came from fred?can u bought for me dat the CPS n ship to me?
Old 04-03-2012, 12:14 PM   #13
fredjacksonsan
Yes, I can certainly send you a CPS, glad to help. They are approximately $90US at the dealer, and less expensive at a parts store.
Let me find out how much they are and I will post back.
edit: I live on the East Coast of the United States.
Old 04-03-2012, 12:20 PM   #14
fredjacksonsan
There are 2 different parts for the 1994 XJ. If you send me your VIN (vehicle identification number) I can find out about the correct part.
Old 04-03-2012, 12:38 PM   #15
fiq
i'll let u know tomorrow moning..thanx a lot!!!!
Suburban Cannot start!! flexxylexxy Suburban 4 09-05-2006 07:39 AM
Cannot start 1999 Lumina vt4000 Lumina 28 07-20-2006 03:39 PM
No electrical equipment working except headlight, cannot start the car nik_istinov General Discussion 3 01-05-2005 09:35 PM
Engine cannot start sometime and getting worst. tehskhg Escape | Maverick | Escape Hybrid 0 11-12-2004 07:17 PM
