Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix
Old 11-29-2011, 11:01 PM
jman401 jman401 is offline
service engine light
Hi, My light came on in my 2001 GT, 3.8 about a year ago during a heavy rain. Since then it has been on and off but stays on during periods of moisture. If I let my car sit for a few days, the light turns off and then on again after driving for a while. When scanned the code read a Mass Air Flow sensor. Should I clean the sensor, change the sensor, or is there something else that is causing the sensor to find a problem? The car seems to run just fine with a little hesitation when first taking off. Please help! Thanks.
Old 11-30-2011, 10:46 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: service engine light
The maf sensor is easily damaged and if you clean it make sure to use electrical contact cleaner. You can get it at Radio Shack. Spray gently. I would also check the contacts on the top of the sensor as they may be corroded and in need of cleaning. If the sensor cannot be saved purchase a new one not a remanufactured unit as they are not of good quality.
2000 GA - Service Engine Light & Trac Light Crystal3477 Grand AM 3 12-08-2005 10:40 AM
Service Engine lights up again! kenchan Maintenance 25 02-06-2004 12:06 PM
Service Engine Light is O?? Jeff M Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 09-19-2001 12:57 AM
Service Engine Light is OFF!!!!!!!!!!! kenchan Engine 0 07-30-2001 10:04 PM
Tags
engine , light , service
