Old 06-01-2003, 12:26 PM
civicHatch civicHatch is offline
Send a message via AIM to civicHatch
Swap Help!!!!
hello,
I have a 88 dx hatch and am planning an engine swap this june. I want to go with the jdm d15 1.5 SOHC V-tec that makes 130hp from 92-95. I can get the full engine for 500 bucks. I have a spare 90 si engine tranny and Ecu so i was going to use the si intake manifold tranny and Ecu and then get a Apexi V-tec controller to activate it. I know you can get a jdm 1.6 SOHC v-tec but whats the difference and what would be the best set-up. I need some opinions.
The reason i am going with one of these motors is the weight I will save by not doin a b series DOHC. I eventually want to race the car in autocross so weight distribution will be key. Any comments and suggestions would greatly help, thank you.
Old 06-01-2003, 12:35 PM
Json79's Avatar
Json79 Json79 is offline
Send a message via AIM to Json79
i know your trying to save money buy goin with 90 si intake manny, ecu and distrubitor, but you wont have the full power as if you were to have the obd1 distrib, ecu and intake manifold... try getting a hold of the 92-95 equip.
I had the setup you were planning in one of my civic. it was horrible.. I didnt like it at all.. low end sucks ass.. but high end. kicks ass.. still sucks
good luck on ur swap.. 500 is cheap..
Greg has a new swap Looks like he needs to get wiring info done. and flywheel then he is all set.. so if anyone got a fly wheel laying around for him.. let him know!!!!!!!!
haha
Need an alarm, deck, dvd system for your ride?Or just want to upgrade with remote start,power door locks or windows?? Im Offering premier alarm/car audio installs for cheap prices. Your equip or mines. Questions...email me at [email protected] from the bayarea./ Nor Cali im also mobile so i can come to you.
'00 Yamaha R6
'90 Honda Civic Si Dohc Vtec My STKB16
FULL time Car Audio specialist/installer
AIM: Tuandang79
Old 06-01-2003, 02:44 PM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
I think its a good idea. there will be no wiring changes, and the engine would be a direct bolt in. especially with the si tranny, you should be a quick car. I have a d16z6 with the z6 intake manifold, but its still OBD0 using pm6 injectors, ecu, distributor and wiring. If i would've had the Si intake, i would've used that just to have ease of installation.
Also, im not 100% sure about autocross regulations, but i belive an engine swap will put you in another category and for a beginner, it would be very very tough to win. You might want to check on that, as most autox dudes i've talked with say to use a 100% stock car until you get very good at manuvering the course, then add mods according to skill.
and yes, its true that you wont extract the most power possible from using the 88-91 si setup, but you will still have a quick car.
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 06-01-2003, 07:20 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
i have 91 si flywheel available, make an offer.......if it works with his swap.....i dunno what swap hes done
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-01-2003, 09:09 PM
GTA's Avatar
GTA GTA is offline
Whee..
z6 swap what do you want for it? i can use my dx tranny and flywheel that i have off my 88 but im getting a si tranny and clutch too i just need a 89+ flywheel to use it...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 06-01-2003, 09:20 PM
.......25+shipping? sound good? im using the 92-95 clutch and flywheel
1991 Honda Crx Si
1995 mustang gt gt40 crate swap on going idle issues dcevil79 Mustang Problem Diagnosis 1 09-16-2010 06:35 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 10:26 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 08:48 PM
94 Psprt 3.2L4x4 diesel swap, wasting my time? bagelpsychic Rodeo | Passport | MU 2 05-04-2009 08:47 PM
Accord Engine Swap? HELP! OhBabyImRidinLow Engineering/ Technical 2 01-10-2002 10:32 PM
