Stats: 98 4runner, 4 cyl, automatic, 2wd, 150,000 miles.
Question: what kind of mileage impact can the O2 sensor(s)have on the vehicle if one or both are bad. Neither has ever been changed. Nucklehead 1 (toyota service guy) says save your $ - just not necessary to change 'em. Nucklehead 2 (auto parts store guy) says Change 'em - could cause as much as 2 mpg loss or even more. Also, what other kind of performance losses can they cause if they have gone bad? Thanks in advance for the input. |
Resident Chemist
Re: O2 sensor replacement question
I don't think they have a substantial decrease in mileage if the front one is bad. Even though you would think so, I didn't notice a difference (although I didn't leave it in for long after I had the trouble code). The rear sensor will not affect performance since it is only a catalytic convertor efficiency indicator.
I wouldn't change them unless you get a DTC (Check Engine Light) indicating one or the other are bad. You may loose some power if the front one is bad. Note that if you receive a trouble code indicating poor catalyst efficiency, it is most likely a bad rear sensor, not the cat convertor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
AF -Advisor
Yeah, either one being bad can cause a noticeable mpg loss, the EFI isn't running in it's most efficient mode.
But if any are bad it should also cause a error code and trip the engine light. Big question, what made you take it to the shop to begin with? If just lower mpg, could be other things.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs 80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ... 89 4Runner - stock 2000 Isuzu Trooper + 2010 Sonata |
