Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-02-2011, 01:38 AM
rsim rsim is offline
crown vic rear axel wear
This is on a 2003 police version This is the 2nd time in 12k miles that this has happened. Do not know which part failed the first time as I had a shop fix it.
This time the axle wore where the outer bearing runs.
See the pictures Please let me know what yoU all think
I also did a hardness test and the one with damage is softer then the other one. i used a file for the test.
So where can i buy hard ones?
Thanks
Rod
Old 10-11-2011, 11:14 PM
Re: crown vic rear axel wear
Smith auto can get me a dorman rear axle for 150.00 and bearing for 29.00
going to use diesel to wash out the oil that is stuck to everything . this should also remove the metal dust. Not sure what to do with it after I get it back together. Sell or keep for a spare. As the replacement I think for 2008 makes noise from 60 to 50 MPH but is quite at other speeds
Crown Vic 5 speed swap, help jnslick Crown Victoria 2 07-10-2010 10:34 PM
98 crown vic rear end problem hdman87 Crown Victoria 3 10-06-2009 10:27 PM
04 PI Crown Vic Zeepian Crown Victoria 0 03-29-2009 02:54 PM
'94 Crown Vic rear level control ??? jaybird67k Crown Victoria 1 03-16-2005 05:38 PM
