Go Back   Automotive Forums .com Car Chat > Pontiac > Bonneville
Old 12-29-2002, 06:17 PM   #1
Bumpa2
Post 3.8 L Coolant leak
My 95 Bonne with 3.8L uncharged engine (90 k miles) is consuming coolant. No external leaks (hoses, clamps, core plugs, water pump, radiator, heater or overflow tank). Coolant side pressure checked hot & cold OK. Coolant sniffed for exhaust; none detected. Here is the crux: the exhaust pipe drips GREEN LIQUID. Engine runs fine (for now). Any comments would be appreciated.
Thanks
Bumpa2
Bumpa2 is offline   Reply With Quote
Old 12-30-2002, 10:37 AM   #2
Shortbus
Blah blah blah
Send a message via AIM to Shortbus
It's not going in the oil pan is it? Thats a weird one. Is your coolant the orange crap (dexcool) or green. How much coolant is it using?
Shortbus is offline   Reply With Quote
Old 12-30-2002, 07:57 PM   #3
Bumpa2
3.8L coolant leak
I've used the green stuff since mile 1. No coolant in oil (drained and settled for separation). I read about several cases of coolant leaking into the intake via the upper intake manifold (black fiber or plastic) but I didn't think coolant actually circulated above the lower aluminum manifold.
Old 12-31-2002, 09:08 AM   #4
Shortbus
Blah blah blah
Yeah we do keep those upper intakes in stock, cause they crack a lot.
I am pretty sure it has to do with coolant leaking. That would be a good place to look.
Old 01-29-2003, 11:18 AM   #5
Scott 02
Banned
Scott 02's Avatar
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
How much are those by the way?
Scott 02 is offline   Reply With Quote
Old 01-29-2003, 11:28 AM   #6
Shortbus
Blah blah blah
The pn is 17113136 and they list at 295.00
If you buy em right on the internet you can get them for 200.
Old 01-29-2003, 11:46 AM   #7
Scott 02
Banned
Scott 02's Avatar
Sound good.
Old 01-27-2004, 08:03 PM   #8
firehawkman
Send a message via Yahoo to firehawkman
Re: 3.8 L Coolant leak
i have 2 of those intakes came off a 98 bonneville not sure of the interchange on them if you can use them ill deal with ya need to get them outta my garage
firehawkman is offline   Reply With Quote
Old 10-17-2011, 10:18 AM   #9
IT247365
IT247365 is offline   Reply With Quote
Old 10-17-2011, 12:36 PM   #10
maxwedge
A990 racer
Please check the dates first ,this is a 7 year thread and the solutions are well known.
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 05:02 PM
99 LeSabre 3800 3.8 coolant leak? Head gasket? Lower intake gasket is leaking.HELP!! chubbygoatboy LeSabre 10 01-03-2010 09:49 AM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
1998 dleta 88 3.8 coolant leak rkpatt Eighty Eight 6 04-18-2008 10:09 PM
