Originally Posted by carl123
I did have a problem with a 1997 quest with hard shifting and codes p0120 p1705 p0325 I did change the tps but problem still so after checking everything found that the computer wasn't getting the signal from tps sensor I did start checking the wire and found the signal wire coming from tps (white middle wire on the top connector of tps) grounded at engine harness after fixing the wire all the problems went away and no more codes just want to share this info someone can used.
Great Post!!! Thank you! My 1997 quest had the same problem and same codes, hard shifthing from 1st to 2nd gear, I was about to have rebuild the tranny, after I read this, I tested the same white cable, found it grounded then I replaced it, and the issue was fixed inmediatly. Looks like this is a common issue on the quest.
