Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-25-2011, 03:14 PM   #1
Camelcavalier
93 set me free?
Ok so I drive a 93 olds cutlass supreme 3.1 fwd and it used to start just fine than out of nowhere I went to turn the key the other day and nothing, battery is fully charged, I have lights and fuel. I jumped the starter motor from the positive to the negative connections on it, car started fine, does this mean my starter motor is bad?
Camelcavalier is offline   Reply With Quote
Old 07-25-2011, 03:20 PM   #2
maxwedge
A990 racer
Re: 93 set me free?
Welcome to AF' No, then the starter is ok, correct? When attempting op start do you have 12v to the solenoid?
The Following User Says Thank You to maxwedge For This Useful Post:
Camelcavalier (07-25-2011)
Old 07-25-2011, 03:27 PM   #3
Camelcavalier
Re: 93 set me free?
I believe so, I just used a small jumper cable to jump it
Old 07-25-2011, 04:32 PM   #4
inafogg
Re: 93 set me free?
it sounds like you dont,thats why jumping works..
check purple wire on solonoid for 12v. fusible link could be blown
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is offline   Reply With Quote
Old 07-25-2011, 05:24 PM   #5
procaddytech
Re: 93 set me free?
You can also try starting it in neutral or while moving the shifter to see if the PRNDL switch out on the trans is loose or has bad contacts. Keep your foot on the brake in case it does start while moving the shifter. A quick easy test.
procaddytech is offline   Reply With Quote
Old 07-25-2011, 06:08 PM   #6
Camelcavalier
Re: 93 set me free?
Thanks for the tip but I tried that earlier without any luck, right now I'm goin after the fusible link, there is not 12v at the solenoid, I'm going to follow that and I'll let you all know how it works out
Old 07-25-2011, 06:55 PM   #7
inafogg
Re: 93 set me free?
have you checked to make sure the fuses are good? under the hood f/box
Live For Today
Yesterday is gone,
Old 07-25-2011, 07:12 PM   #8
Camelcavalier
Re: 93 set me free?
Yea that was one of the first things I checked, I've been burned 1 or two times because of bad fuses, I'm going to finish working on the car tomorrow afternoon, I'll let ya know how it goes
Old 07-26-2011, 05:14 AM   #9
procaddytech
Re: 93 set me free?
Here's a schematic if will help:
The purple runs off the right side of page to the solenoid and the other half of the page is the charging system.
1 set Free Spark Plug Wires in Delaware Bill()C Corsica 3 03-28-2006 11:17 AM
With skills like this, he should be set free... Hyatus COMPLETELY off-topic 3 07-04-2004 07:10 PM
Tags
cutlass , oldsmobile , problem , starter
