Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 07-08-2011, 12:19 PM
dreamgurl522 dreamgurl522 is offline
99 Cavalier wont start.. have tired everything
I have had my 1999 Cavalier for almost 2 weeks now. Never had any issues until lastnight when it wouldnt start. The car wont even turn over. What should I do? Jumping didnt work. Turning the steering wheel didnt work. It is already in park.
Old 07-08-2011, 02:10 PM
jdl jdl is offline
Re: 99 Cavalier wont start.. have tired everything
Did you try cranking in neutral? You have to be positive the battery has a full charge and connections are clean and tight.
The purple wire at the starter solenoid S terminal should be hot/voltage, with key in the crank position. If it isn't, backtrack the circuit. With automatic tranny, that circuit is wired through the neutral switch, with a manual tranny, it is wired through the clutch switch.
If you think the starter itself has a problem, some of the national brand autostores will test it for you. Take it off and take it to them.
Note wiring diagram.
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
2000 cavalier wont start shortytdd Engineering/ Technical 0 05-15-2004 03:18 PM
94 Cavalier Wont Start JGP Cavalier 0 04-10-2004 07:31 PM
2001 cavalier wont start with half tank of gas munns Cavalier 0 06-04-2003 08:12 PM
