Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-26-2010, 10:16 AM
jjwg3 jjwg3 is offline
Disconnect Rear Air? 96 Suburban
How do I disconect the lines to the rear a/c system on my 96 suburban. I believe the leak is back there and nobody ever rides back there anyway. I little a/c up front is all I need so I'd like to just disconnect it.
Is there a way, or place, to plug those lines heading back there?
Thanks in advance.
Old 06-26-2010, 11:42 AM
Re: Disconnect Rear Air? 96 Suburban
Sorry about the duplicates! It wouldn't post, then I'd go to the index to be sure it didn't and it wasn't there. Next thing I know...bunch of duplicates. Should have known better. Sorry!
Old 06-26-2010, 11:08 PM
777stickman 777stickman is offline
I do not know of a way to bypass the rear A/C. Best to take it to a good A/C mechanic and ask them. It's not like bypassing a heater problem.
To delete your duplicates go to each post and click on EDIT. At the bottom left click on "delete message". You don't need to put a reason in. Then at the bottom right click "delete message".
Kind of cleans things up.
Best of luck to you.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-27-2010, 09:01 AM
Elbert Elbert is offline
look here.
http://www.rayeveritt.com/
noticed there were some fittings related to suburban A/C
Also a place called "doc's blocks"
Elbert Clarke
Old 06-27-2010, 09:38 AM
Thanks for the input. As for deleting, I have tried everything and lokked everywhere for that delete button. I hit Edit/Delete, but can't find anything that will actually delete it.
Still trying...
Old 06-27-2010, 03:40 PM
Cusser's Avatar
Cusser Cusser is offline
I don't have rear AC in my Suburban anymore (bad rear expansion valve), and I'm in Arizona, but you have a leak. I'd consider the fittings available on that site to block off the rear. Otherwise, you can take the front part of your metal lines for the rear AC and have them welded shut, then re-install them (with new O-rings).
To by-pass the rear HEAT, like with a leak, you can use Gates molded 3/4 hose #19607 and bypass just under the passenger front door.
Old 04-20-2011, 01:17 PM
hoppy26 hoppy26 is offline
There is a web site called www.streetrodguys.com that has rear a/c block kits and rear a/c line repair kits for just about any vehicle. Highly recommend this site I have bought several fittings from them and have never had a problem with any of them.
