Go Back   Automotive Forums .com Car Chat > Ford > Five Hundred
Old 01-27-2011, 04:01 PM   #1
scotto4837
Alternator went out, no warning
If you see these symptoms, watch out. First, I lost a new battery. Replaced it and two months later, the car started rough - kept dying after starting. Then it idled too fast. Then, driving down the expressway the radio went out. Then got ABS warning and Traction Control warning. Lights went out. Car died.
Had to replace the alternator. Problem solved. But, there was no warning other than the above before it simply died on the road.
Man I miss the Charge / Discharge gauge!
scotto4837 is offline   Reply With Quote
Old 01-27-2011, 05:15 PM   #2
old_master
Advisor/Moderator
old_master's Avatar
Re: Alternator went out, no warning
Originally Posted by scotto4837 View Post
... the car started rough - kept dying after starting. Then it idled too fast. Then, driving down the expressway the radio went out. Then got ABS warning and Traction Control warning. Lights went out. Car died....
What kind of "warning" are you looking for? The car was practically screaming at you that something was wrong. When you didn't listen, it shut itself off! Most auto parts stores have voltmeters for under $20.
You have to know how it works,
to figure out why it doesn't.
old_master is offline   Reply With Quote
Tags
alternator
