Go Back   Automotive Forums Car Chat > Chevrolet > S-10
Old 04-08-2002, 12:22 PM
dhcarss dhcarss is offline
Send a message via AIM to dhcarss Send a message via Yahoo to dhcarss
mpfi 4.3 egr valve
Has anyone had any problem with theres sticking..
3geez member since Feb 12, 2001
Old 12-01-2002, 09:37 PM
BOWTIE BOWTIE is offline
VACUUM OR DIGITAL VALVE?
Old 12-03-2002, 05:31 AM
cobra1 cobra1 is offline
the digital type EGR valve on my 95 s-10 4.3 vin W made it all the way to about 150,000 miles before carbon build up kept it open. i merely took it off, cleaned it, and put it back on. im up to about 175,000 miles now.
Old 12-15-2002, 07:14 PM
www451oa www451oa is offline
Question Location of 94 EGR Valve
I've got a 94 S-10 Blazer, 4.3L CMFI. My computer comes up with code 32, which is my EGR Valve. My only problem is that I cannot find where the EGR valve is located. I know exactly what it looks like, but no clue where to find it.
Old 12-15-2002, 09:11 PM
looking at the front of the motor, under where the air intake tube goes into the upper part of the intake manifold is where the EGR valve is located. the only thing connected to it is one electrical connector, as it is of the digital type and not vacuum operated.
Old 02-26-2003, 11:27 PM
Firetamer7 Firetamer7 is offline
Send a message via AIM to Firetamer7
Exclamation egr valve 1995 s-10 blazer malfunction
:flash: I have a 1995 s10 blazer 4x4 with a 4.3l vortec and it has had 3 replacement egr valves, it is at 112,000 miles and is having recurrent episodes of egr malfunctions. I have cleaned it numerous times. Good luck, i also read on edmunds.com that this is a common problem. So if anyone has a solution ,, tell me please.
Old 03-28-2003, 08:41 AM
bonnovy bonnovy is offline
94 s-10 egr
I have a '94 4.3L w/ vin "w". Does anyone know if the egr from a '95 4.3L will work. I also suffer from the dreaded sticky valve problem. FYI Chevy's answer to this is a gasket you can get from you're local dealer with a screen in it, to keep out the carbon deposits.
Old 03-28-2003, 09:57 AM
when i looked up both 94 & 95 vin "W" s-10's, it shows different part numbers.
Old 05-16-2003, 08:06 PM
jbrewster11 jbrewster11 is offline
'95 S-10 EGR
Can someone tell me what dealerships have that EGR valve with the screen on it? I called my local dealership and they think that it is an aftermarket part?
Old 05-17-2003, 12:17 AM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
It's not actually the valve that has it it is the gasket. I think it is from Tomco or something to that effect
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 05-18-2003, 09:18 PM
'95 S-10 EGR
Thanks.
Selling or Parting 93 jimmy 4x4 4.3 Votec(w) ibceng Classifieds 1 10-08-2009 04:34 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 06:33 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 10:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 11:45 AM
1997 3.3 EGR valve location Boneyard Caravan | Voyager 2 11-25-2005 11:16 PM
