Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-18-2011, 10:53 PM   #1
fastmoney
Low trac light
I have a 1996 cutlass supreme 100,000 miles ..when i press the brake hard enough the low trac light will come one and I will here what i believe is the abs unit...This also happens if i hit a big enough bump...it started in the summer time when the road was dry and I didn't slide...and now it happens almost every time when the roads are slick because now its winter here.
Maybe struts? abs unit? wiring?
fastmoney is offline   Reply With Quote
Old 01-19-2011, 04:16 PM   #2
maxwedge
A990 racer
Re: Low trac light
Slick roads, is a wheel actually skidding /locking up?
maxwedge is online now   Reply With Quote
Old 01-19-2011, 09:56 PM   #3
fastmoney
Re: Low trac light
well it comes on when I slide but i guess thats normal.. But Like i said it also comes on when i hit a bump...Its seems to be more prominent on the front passenger side....
This started happening in the summer time on dry surface no slidding.....
Old 01-20-2011, 02:54 PM   #4
maxwedge
A990 racer
Re: Low trac light
I would suspect a bad wheel speed sensor or the wiring to it. to be sure a a scan with an abs function scanner would look at wheel speed inputs.
Old 01-20-2011, 09:28 PM   #5
fastmoney
Re: Low trac light
aw ok thanks I will check that out
