Installing headers
When installing headers on my 5.0 L K1500 is there any special precautions I should take? I talked to a fellow mechanic at work and told him I was putting headers on my pickup and he said not to because he put them on his El Camino and they "melted everything." What do I need to do to prevent that from happening.
Also when putting on the headers is there a place to screw in the oxygen sensors on them or am I going to have to modify that set up in some way? |
Re: Installing headers
You can reduce the heat emitted by buying headers with a ceramic coating. Also make sure that all wires and hoses are held clear of the hot surfaces by using zip ties. Do not use the header heat wrap as these can retain water and cause rusting of the header.
Most headers do come with the welded-in bungs needed to install O2 sensors, so no need to fuss with them yourself. Just verify that what you are buying is for your vehicle year and engine...most will have a bung for each bank for the pre-cat sensors, but if your truck is pre-1996, you won't need them since the single bung is located in the y-pipe...just leave the plugs in. Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
when headers are installed the rapid exhaust cooling can reduce power by increasing exhaust back pressure.. with insulation this is eliminated..don't need much to achieve this.. using plug wire heat loom with this 5.0L may also be needed... |
my nephew just sold a brand new pair of ceramics he put them on graigs list i think he sold them for $80.00 if i new hew was selling that cheap i would've bought them.
Also when buying headers, pay attention to how they block the spark plugs/plug wires. With headers, chances are you are going to have to use a wrench instead of a spark plugs socket and ratchet.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
