1995 Lumina still wont shift!!!
Hello, I have a 1995 3.1L V6 Lumina. I was putting the car into reverse, and it like popped into it. The the speedometer quit working, and the transmission wouldnt shift out of first. So I looked it up, and everything pointed to the speed sensor. So I changed it, and it's still doing the same thing. What else could it be? I really miss my car! Thank You.
Re: 1995 Lumina still wont shift!!!
Welcome to AF, make sure you have vacuum to the modulator to start with.
Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.11) Sprint PPC6850SP |
L/s of trans down low there is a small cannister with a vacuum hose to it, engine running, make sure there is vacuum on the hose when disconnected from the modulator. BTW, is the speedo now working, if not that must be traced and repaired first.
vacuum really has nothing to do with shifting other than "shift feel",,,reverse still good???? tranny known for damaging reverse reaction shell "stove pipe",,which usually goes out with a clunk,,,or bang,,,then up-shift issues occur,,,piece is needed for 2nd clutch input,,,,,,though would not account for vss problems
Yea reverse works just fine. Just the speedo and shifting up thats giving me issues. Anything else i should try?
no real advice,,,,a scanner would be nice,,,,not a code reader,,,to see live data in real time to see what the processor is getting from vss....another dumb thing is to check fuses gbaum
The VSS sends electrical pulse signals to both the speedometer and the ECM, through the instrument cluster. If replacing the VSS doesn't solve the problem, then there may be a faulty electrical connection on the instrument cluster.
those were good for tranny problems my son and his wife had to put new tranny or rebuilt in theres twice.
