Rear Subframe Insulators/Cushions/Mounts STUCK - 2002 3.8L with reinforcement bracket
Regarding the subframe mounts, I was able to change the front two, but the bottom of back left one (the top part) is literally jammed into the subframe. I tried prying it up from the sides, whacking it from underneath with a hammer (something started smoking?!?).. *nothing* will budge it. So I put the bottom part back and bolted it back up and left it alone.
Does anyone have ANY hints on how to press that thing out of the subframe? It looks like it's stuck into the bracket that was put on as part of the subframe recall. I had more than enough clearance above it so that it should have been able to move out of the hole. If this is too confusing I'll try to post some pics. BTW - thanks to everyone for shaing so much valuable info on here. I went from hating this van to developing an "understanding" with it. Also, I asked the ford dealer where I bought the bushings if they could install the back 2 for me. They said it would be $469. I tried my best not to simultaneously laugh out loud and spit in the guy's face when he told me that. Old thread about these bushings here: http://www.automotiveforums.com/vbul...d.php?t=763484 |
Re: Rear Subframe Insulators/Cushions/Mounts STUCK - 2002 3.8L with reinforcement bracket
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
I appreciate the input.
As for the bushings, I rented a large 3-jaw puller from oreilly's and bought a can of CRC freeze off. I'm about to go brave 90+degree heat to give it one more shot. (Hoping the heat plus the freeze spray will finally break this stupid thing loose.) If that doesn't work, I'm just going to live with the old ones. |
I've changed all mine ... it was a few years back. I don't remember any difficulties. I rarely drive in much slush or salt, so there was little rust to contend with. Good luck. Be careful with that flame!
Know what it is? It's that megastrength glue they used for the recall bracket. I took it off again this afternoon and looked more carefully at it. The rubber pries up no problem but the round metal part is completely stuck to the frame. Now I need to find something to dissolve that adhesive. Sheesh, what a pain. Looks like I'm going to have to give up on this one or find someone with an OA torch who won't charge me an arm and a leg.
| Tags |
| cushion , insulator , mount , stuck , subframe |
