Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 12-28-2010, 06:13 PM   #1
rodgerturner
Overhead Console 98-99 Venture
Hey guys,
Decided to pull the console display and found where the loose connection was... question - - - how do you reapply this piece? (It's the little piece with "430" stamped, above and to the right of the display board.
I have two displays and this is the problem on both!! Thanks!
rodgerturner is offline   Reply With Quote
Old 12-28-2010, 10:07 PM   #2
rodgerturner
Re: Overhead Console 98-99 Venture
Got it! Just needed to tack it back down on each end with some solder. Hopefully this helps someone with a non-working display.
Plug it in and press around on the various boards... if you're lucky you'll find the one that is loose when the power returns. Careful as those boards will heat up quickly and will be hot to your fingers.
As I said, i've got 2 boards now, both were loose at that top "430" plate.
(No idea what they are called or how they work...lol)
Cheers!
Old 12-29-2010, 11:35 AM   #3
venturenot
I have a 98 chevy and was wondering how did you unplug DIC from wiring harness. Is there a tab on the red connector that I depress to do this.
venturenot is offline   Reply With Quote
Old 12-29-2010, 08:08 PM   #4
lesterl
lesterl's Avatar
That my friend is a resistor. 43 Ohms IIRC........ Thanks for the info!!! :-)
Question: Has anyone added one of these consoles to a non console van? What was involved? (I would be interested in doing such.)
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
lesterl is offline   Reply With Quote
