Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-03-2011, 02:11 PM   #1
rs6er
Parking Brake Question.
The left parking brake shoe was rubbing inside the rotor drum. It has worn the inside of the drum unevenly. The rotor itself is fine. If I get the parking brake shoe alligned and secured properly, do I need to worry about the uneven wear inside the drum (assuming I don't care that much about the parking brake)? Or will this uneven wear force the shoe out of allignment?
rs6er is offline   Reply With Quote
Old 01-03-2011, 03:08 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
Re: Parking Brake Question.
Yes, it could cause misalignment, further drum damage, and generally make it very difficult getting the drum off if the shoes wear bad enough.
I'd suggest having the rotor/drum turned and replace the shoes. If the hardware is the original, have it replaced, too...it's only an extra $15 for the parts. This will ensure that you don't have a weak spring causing the misalignment.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 01-03-2011, 03:25 PM   #3
rs6er
The rotor is in good shape. Can they just do the drum? If so is there a minimum thickness for the drum part?
Old 01-03-2011, 03:33 PM   #4
jdmccright
The RustBuster
jdmccright's Avatar
I don't see any reason they can't just turn the drum part, but you might have both sides done so you have a consistent surface on both sides of the axle. Since the P-brake shoes will drag slightly, if they are up against differing surfaces L-to-R, it could cause a slight pull to one side.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 01-03-2011, 03:42 PM   #5
rs6er
Is it necessary to be consistent? It's just for parking.
Old 01-03-2011, 03:57 PM   #6
jdmccright
The RustBuster
jdmccright's Avatar
Not necessary, but as mentioned, if the truck pulls slightly to that side when the brakes are adjusted that's the reason.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
parking brake vs. car in park...help! CVCchic85 '96-'00 Civic 1 08-09-2010 10:56 PM
Parking brake tbird -92 5.0 bennylw Thunderbird 4 06-14-2009 04:24 AM
99 Sunfire Parking brake Question and engine question agco85 General Discussions 0 05-28-2008 09:47 PM
Parking brake question robotech021 Elantra | Avante 2 07-10-2007 12:52 AM
