Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 06-25-2008, 08:02 PM
Ladydi_87's Avatar
Ladydi_87 Ladydi_87 is offline
Engine size in a '66 C10
We have a 1966 Chevy C10 we plan on restoring and would like to find out what size the engine is. The current engine is not the original one and is actually from a '75 Nova. All I can remember about the original engine is that is was a straight 6. I have the original engine number. Can I tell by that?
My dad bought the truck brand new in 1966 so I have a ton of history with the little truck.
Di
Old 06-25-2008, 08:13 PM
Toolman56 Toolman56 is offline
Re: Engine size in a '66 C10
Engine's for that years were 230 cubic inch , for 6, 283-327 V-8 cubic inch or if gmc a V-6 215
Old 06-26-2008, 12:33 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Are you looking to find a '66 block to install?
IMO it's probably not worth it, unless you are doing a concours perfect resto, which would be a bit unusual for a pick up.
The Nova engine will be visually identical to the original (if it's a six cyl.), but probably is a bit larger, at 250 cid. Also, the Nova engine has hardened valve seats for using unleaded gas; something the original engine probably did not have.
Old 07-21-2008, 09:36 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
I think the 292 ( 6 cylinder ) was also available in 1966 . You can tell it from the 230 by the motor mount locations. The 230 mounts were straight across from each other where the 292 mounts were offset from each other . Hope this helps ?
Old 07-25-2008, 09:32 AM
MagicRat's Avatar
Good point. I had forgotten about the 292.
Old 11-26-2010, 10:50 AM
Smile Re: Engine size in a '66 C10
Hi, i know my brother has a 327 block torn apart came out of a 1966 chev 3/4 ton same motor that came in those years , he sell it super cheap with lots extra parts Everett
Old 12-01-2010, 03:38 AM
Hi, forgot too add if you are the orginal owner or buy it second hand, look in the glove box or stapled under the seat will be a build sheet for that truck, it will ether list as code or actual engine, also the owner manual, might be stuffed in there with bill of sale, all depends on what you order from the factory and want your pickup to do, but i'm pretty safe too bet it was the 230, with three on tree as a common setup, and the 292 was for more heavy duty apps, Everett.
Old 12-01-2010, 03:44 AM
PS my brother lives sw of you about @85 miles, he had 64-66 chev's trucks and know these trucks and he had a 66 chev truck in a car show few times, i can ask him for sure and myself had the 62 model flatbed , 64 chev ,so between the two of us we have over 34 years in chevs, Everett
