![]() Join Date: Mar 2005
98 Tahoe Steering Wheel vibration
Okay, this one has me puzzled....
I just got a set of tires put on my 98 Tahoe, (4wd, 115K miles) and I noticed a wobble/vibration in the steering wheel around 35 mph, that seemed to go away around 45 mph. It felt like a bent rim, and i figured it was one that was in the back I did not know about or something, So I swapped the front tires to the rear. no change.... I looked at inner and outer tie rod ends, pitman and idler, and everything seems in sorts. I replaced the inner and outer tie rods a good year ago, probably 15-20K miles previous. Recently there was something that knocked the toe out a bit, and I got everything parallel, but I suspect the alignment off a slight bit, which I want to get aligned, but want to fix anything else before I do so... From what I read on the forum, so far, this sounds like a possible front hub, but I am not sure. I don't know why I want to think ball joints, but they seem to be on my list. From the discussion on rotating items causing vibration, that is why I am thinking hubs... Here is more detail to what I get. The vibration starts after the Tahoe rolls over something in the road, a bump, highway separation, sewer cover, etc.... it needs to be going around 35 mph, at least, and the steering wheel starts moving back and forth, maybe a 16th of a turn, a bit less. The steering wheel does not center, but when you put it in perfect center, if the road is level, it will go down the road almost perfect. seems I notice the vibration if the road is more banked, and the wheel is slightly to the right, and the above conditions are present. I guess I am looking for any advice as to how to diagnose whether I got a hub going bad, and what I can do to determine which one it is. I don't mind changing one or both, but would prefer to only change one, if only one is bad. So if anyone has any ideas, any help would be appreciated. Thanks! |
I know stuff
![]() Join Date: Jul 2003
Re: 98 Tahoe Steering Wheel vibration
What you are describing is a shimmy. Typically this is caused by a worn steering component.
I would venture to say that the pitman arm is what I would inspect closely. Also the fact that the toe has been knocked out would indicate damage with the steering system. Good physical inspection is needed
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
The President
did you ever pinpoint the cause of this? I'm having a similar issue with my 98 Tahoe.
