Old 11-28-2010, 05:51 PM   #1
gpgt98
Possible transmission fluid leak?
1995 Lumina 3.1. 130K miles. Rarely used. Leaking ( or should I say gushing ) what looks like rusty looking fluid. It is coming from very near the front of the car. The brakes do not work. Pedal goes to the floor. Checked the fluid level. It was Ok. Thought at 1st it was coolant but the coolant level looks OK. I checked the trans level and it was only at the " add 1 pint". This after losing ALOT of liquid. Looks to me like it was a trans line that has rusted. Does the trans fluid get to look like this?
gpgt98 is offline   Reply With Quote
Old 11-28-2010, 07:44 PM   #2
maxwedge
A990 racer
Re: Possible transmission fluid leak?
Could, clean up the area, have someone start the car, pump the brakes and see what is what, no other way. I would think the brakes would be an issue with a broken line, no?
Old 11-30-2010, 07:21 PM   #3
gpgt98
When you think about how much brake fluid is in the system you would be talking about gallon(s). Nor would it be GUSHING out unless under pressure. From what I could tell it was coming from under the the radiator, from small tubes that looked like it went to the transmission.
Old 11-30-2010, 07:41 PM   #4
maxwedge
A990 racer
Those are the trans cooler lines, a common area for leaks.
2000 Windstar transmission fluid leak olopezm Windstar 16 09-17-2010 09:51 PM
1998 Caravan, transmission fluid comes out of dipstick tube miller5531 Caravan | Voyager 2 08-30-2010 12:58 PM
Transmission fluid leak Catherine Probeck Aurora 6 11-27-2003 03:05 PM
Exhaust and transmission fluid leaks jeremyva Engine 1 05-07-2003 07:44 PM
Dang! Ran over something and all my Transmission Fluid leaked out! green96accord Accord/TSX/Accord Hybrid 2 03-13-2003 06:32 PM
