Go Back   Automotive Forums Car Chat > Ford > Escort
Old 12-09-2010, 05:57 PM
crazydriverz crazydriverz is offline
car running.disconnect batt and vehicle dies...
i was testing my temperature switch because the gauge dont work. so i was running the engine and had to move the battery out of the way (by disconnecting it totally) to test the temp switch and the vehicle would die within 15 secs of removing the battery. is this a problem i need to fix before we get more snow here in michigan? would it be a alternator problem?
Old 12-09-2010, 07:31 PM
danielsatur danielsatur is offline
Re: car running.disconnect batt and vehicle dies...
That's like pulling the plug on your electric fuel pump, and turning off your computer!
Old 12-10-2010, 07:31 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I can't say about Escorts but it used to mean that your alternator was bad if a car did this. It should run without the battery and the alternator provides electricity. But I really don't know nowadays. If you haven't been having any trouble then I'd say leave it alone.
Turn on your ignition and disconnect the temperature sending unit. Check the gage. Then ground out the wire that goes to the sending unit and look at gage. On one of these the gage will peg out and the other it won't move (forgot which). If it doesn't then the gage is bad. If it does then the sender may be bad.
Nevada Tumbleweed
Old 12-10-2010, 09:26 AM
Older automobiles could get away from a disconnected battery, but newer
Auto's can't!
Old 12-10-2010, 10:32 AM
ok ill give it a try and see what the temp needle does. as for the stalling i can see how newer vehicles would need a battery to stay running. i guess my thoughts were alil old fashion.
Old 12-10-2010, 10:32 PM
denisond3 denisond3 is offline
I have three 2nd gen. Escort LX's. I know two of them will run, or idle anyway, with the battery disconnected; and I never tried it with the 3rd one. I suspect its a function of how agreeable the voltage regulation function is. Yes the alternator can produce plenty of electricity, but even a very brief interruption to that output (which is controlled by the regulator) would result in the engine stopping. Something as transient as the a.c. compressor cycling might be enough to cause the engine to stop, or dirty brushes or a worn slip ring on the field coil.
Since there is no service procedure that calls for removal of the battery with the engine running - I wouldnt do it routinely. But neither would I consider there was anything that needed fixing if it DID stop when I disconnected the battery.
Old 12-12-2010, 03:28 PM
I haven't been able to test the wire coming iff the temperature switch. I need a second person. However I did run the vehicle for about 5 mins .turned it off,disconnected the battery and hookked up a multi meter(set at 20k) and was reading the temp switch. It would start at about 10.+ then climb too 16.+ would that mean my temp switch is still good?
Old 12-13-2010, 07:56 AM
It would sound like it is working.
Nevada Tumbleweed
Old 12-17-2010, 12:49 AM
Intuit Intuit is offline
From what I've read elsewhere, disconnecting the battery on an electronically controlled vehicle is about THE WORST thing you can do.
As I understood it, the battery behaves like a big capacitor. Yes, it takes care of volt(amp) drops, but more importantly it filters amperage spikes! Minus the battery, you're risking rather expensive damage to your vehicle's electronics.
From my work with electronic devices I can say, electrolytic capacitors don't last forever and it wouldn't surprise me if most of them in nearly every Escort are bad. Even good, they likely do not have enough capacitance to handle a serious spike, but they're being bad means virtually no protection when the battery is disconnected from a running system.
Tuned.com's Fast and Furious Release Party and Car Show April 3rd and 4th HotCtyPlaya North East 2 03-28-2009 04:32 PM
Car jerks while driving and then dies. dallas_clement Camry/Camry Hybrid/Vista 5 01-04-2008 11:03 AM
Car runs for 10 minutes then dies celinedrules Beretta 2 05-21-2007 09:30 PM
Car running like shit and running rich metalhedskater Eclipse Problem Diagnosis 4 04-26-2006 02:32 AM
why when i turn left does the car say low fuel and sometimes die cricketpoof Caprice 6 08-23-2005 10:01 PM
